Power Steering Leak
Old Nov 12, 2009 | 07:31 AM
Vee70's Avatar
Default Power Steering Leak
Hi
I just bought a 99 S70 and peridocially seeing a complete drain of power steering fluid.
No leaks around the resovoir.
Pump? And is there any possibility of damage to the rack while driving with ought fluid??
Thanks!
Old Nov 19, 2009 | 01:54 AM
It's got to be leaking from somewhere... Fill it up and find the leak, don't stop looking until you do. I have no knowledge of where the fluid flows but operating the steering with no fluid in it will damage something.
Old Nov 19, 2009 | 03:49 PM
Check the rack for the leak... Around the boot areas. Mine was leaking from there. A nice oh $1400 replacement rack was um needed.
Old Nov 26, 2009 | 11:04 PM
nub0t's Avatar
Definitely check the boots.
I replaced my rack back in April because it was leaking from the passenger side boot (the driver side was fine). Got a good used one online (be sure to check it when you get it--the one I received initially had a plasma torch cut in it).
Putting it in was a real PITA--you can find a pretty good guide on replacing it online. If you're not up to doing it yourself, then don't torture yourself--spend the money to get it done right.
ROBLU540
Feb 20, 2009 07:59 PM
samadkins29
Aug 9, 2007 01:31 AM
reg
Apr 3, 2005 03:29 PM
reg
Mar 17, 2005 07:57 PM
