Passenger exterior handle won't open door.
Old Mar 21, 2010 | 05:08 PM
karutunian's Avatar
Default Passenger exterior handle won't open door.
As the title states, the passenger front door handle won't open the door. It opens from the inside, not the outside.
I've pulled the door panel. When working the door handle, I can see and feel the part that would pull the lock to open the door.
I tried to pull the door handle off after removing the two screws on the side of the door, but couldn't get it to release.
I also attempted to remove the lock actuator after removing those two screws...but it wouldn't come out either.
I was concerned about breaking things since I'm not certain how all the bits and pieces are attached. I didn't want to do further damage so, I put it all back together.
Does anyone have access to diagrams that would display all the pieces involved in removing the actuator and exterior door handle?
If not, can someone please give me detailed instructions on how to remove these pieces without doing damage to either the door handle and actuator?
Thanks for any assistance!
Ken
Old Mar 22, 2010 | 02:21 PM
karutunian's Avatar
Uggghhh....35 views and no suggestions. :-(
Seriously, does anyone have any info pertaining to how the exterior handle is connected to the lock mechanism?
Ken
Old Feb 19, 2011 | 04:54 PM
zimmerj2's Avatar
Ken,
I have similar issue, but door will not open from the inside ... only the outside. I was trying to get off the door panal, but having problems ... how did you learn to get your off?
If I find a detail of the lock mechanism I will let you know.
Regards,
Joe
Old Feb 20, 2011 | 10:26 PM
Mr. Pink's Avatar
Originally Posted by zimmerj2
Ken,
Regards,
Joe
i am having this exact problem(ps front door wont open from the inside)
Old Feb 23, 2011 | 03:00 AM
Tyler 99 S70's Avatar
I have not had this problem with my Volvo, but when I used to work at a auto glass shop I would see this alot, mostly on the often stolen hondas, when you pul,l the handle it moves a barinside the door that has a cheap plastic adapter on the end to move the latch, unfortunately, these often break, but can be jury rigged with wire or a clamp until a new adaptor can be found/ordered OR there is a child saftey feature enabled so stop the inside handle from working ( the switch is on the side of the door near the latch). Hope this helps, I will check on the proper steps to removing the door panel, should just be clips though...
Old Aug 8, 2012 | 10:20 PM
Erinjohn01's Avatar
Default Exterior Passener Door is now broken....help
Have any of you guys gotten this fixed yet...? apprecaite any help, if someone answere do i get an email telling me to go to this site? anyone know.
just in case im erinjohn08@hotmail.com
thanks
Erin
1994 960 Wagon
Old Aug 9, 2012 | 08:39 AM
Mr. Pink's Avatar
I replaced the interior handle and the cable going to the latch mechanism. but i havent owned my volvo in almost 1yrs now.
Old Aug 9, 2012 | 03:18 PM
donf's Avatar
Did this beginning of the year, unfortunately I've had a few beers since then and the memory is not too good. Took some pictures, it's not hard, just tedious. Think of one of those "Chinese Box Puzzles". Basically you have to take everyhing off. The liitle hole above latch with a rubber stopper in it is too help align things when reassembling. [ATTACH]Passenger exterior handle won't open door.-door-latch-1.jpg
Passenger exterior handle won't open door.-door-latch-5.jpg[/ATTACH]
Old Aug 9, 2012 | 03:24 PM
The handle has a slot on an arm that attaches to the top of the latch.
Old Mar 14, 2021 | 04:20 PM
stevesecor's Avatar
So although this thread is some years old, It looks like there are people who have had problems with both the inside and the outside handles. I have a 2011 C70 and the driver's door will open from the outside but not inside. Took it apart and the cable is all attached and actually does move the little part on the inside of the door but doesn't go so far as to allow the door to open.
Any suggestions?
Old Mar 27, 2021 | 05:44 PM
Ga Ko's Avatar
Ken
Hi Ken
I don’t have your model but would suggest searching eBay for the part and look for the mechanism to maybe get an idea.
Here is what it looks like for a 2017 XC90
Good Luck!
Ropsal46
Aug 3, 2024 10:57 PM
rcvolvo
Apr 10, 2016 01:26 PM
Amigorick
Apr 7, 2013 10:19 PM
Nolasim
Nov 29, 2012 07:06 PM
ss~zoso~ss
Mar 3, 2007 01:25 AM
